RTV 1120D glow plug relay location. Can't find it, any help greatly appreciated
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,252
1,035
Williamstown Ontario Canada
On a more serious note, looking at the Messicks parts stuff I see one 20 amp relay located as seen below.
I have no idea if it is a Glow Plug relay or even if your machine would use a relay for the glow plugs as most are controlled by the key switch.
Relay is part number K7311-62310 for $16
Dave
whitetiger
Nov 20, 2011
3,074
1,515
Kansas City, KS
Can anyone point me to the glow plug relay on a RTV X 1120 D? Thanks
Look in your Operators manual, it shows pictures of lifting the seats, removing the tool tray, and the access cover where you will find the fuses and relays.
sharrisc
X1120D
Oct 30, 2021
Temecula, California
Thanks, all fuses tested good-took the relays to dealer, they tested them as good. I noticed a relay under the hood, attached to the ignition switch harness, 20 amp, I think. Would that be it?
