When I try to raise the box blade only one side comes up what do I do the left side works fine the right side you can raise by hand
You have to give us at least a hint on what tractor your working on!If the rock shaft is twisted off in the case is it a hard fix and what does it intale
sorry it a b7210You have to give us at least a hint on what tractor your working on!
our Kubota dealer here is so back up it takes a month before they can look at so if I can fix it I try tosorry its a b7210
Thanks for your reply you can pick up the right arm by hand and the shaft doesn't move so it must be the spline but where the bolt that attaches it to the shaft
