Well, I sheared off the output shaft on my Rhino 172. I didn't even hit anything of substance, I think it'd just given all it had to give over the years.
I started the swap yesterday but ran into a point where I figured some advice by you guys would save me a LOT of heartache in taking wrong paths to the solution.
Here's the new shaft (~$250+...ouch!)
And here's a labeled picture of the Comer gear box. Will the output shaft come out of the top of the gear box? I've replaced a bottom seal before, mistakenly disassembling the gear box before realizing I could replace the seal only from the bottom...doh! But this gear box seems a little trickier to remove the top horizontal shaft. Does anyone have an idea the sequence with which I'll remove things to get to the output shaft? Will I have to tap out/press back in any bearings?
