Replacing hydraulic hoses...kinda scared
pvk
14
I have just emptied my b1700hst transmission oil, spin-on filter and cleaned the transmission filter screen on the tractor. My question is that I now have no transmission/hydraulic oil left in the unit, can I remove and repair leaky hoses without worrying about it shooting oil everywhere or getting injected with hydraulic oil and being in a world of hurt?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
It may still have pressure on the lines. If it's on a loader work the control back and forth and it should relieve any excess pressure on the system. I would then just crack the line loose and slowly bleed off the remaining fluid. You are smart to use caution reguarding hyd lines though.
pvk
14
Yes, the lines are from the loader. I have moved the joystick in every direction possible to relieve pressure, now comes the scary part, removing the lines and hoping nothing bad happens.
Thanks
Bulldog
Mar 30, 2010
5,434
78
Rocky Face, Georgia
Just make sure the bucket is sitting down and can't move. You should be fine to loosen it up and remove the line. Good luck with it.
gktilton
B7500 with Loader and MMM. Woods M4 Bush Hog, Kuhn Rototiller, 3PT Snow Blower
May 5, 2010
234
Hooksett, NH
Listen to Bulldog and you'll be fine. If you don't KNOW that there is no pressure on a line just remove it very slowly if there is pressure you will notice weeping before there would be anything violent. If it weeps leave it until it stops and then crack it open a little more. Never been hurt by one but have removed some that were under pressure on attachments that I had not disconnected. Caution always in order with hydraulics and PTO shafts.
me109stock
B6100E w/ FEL
Feb 29, 2012
Stockton, CA, USA
I blew an OLD line, so no worry about pressure, but now that I've replaced the line is there a need to bleed the system to get the air out, or do I just move the controls around until the air pocket gets back to the return line and the resevior?
Nevermind - answered to my own question - no bleeding required per another post I found, just move the controls around.
Buse
B6100 with FEL
Oct 3, 2011
40
Sweden
Swapping the tubes should be easy. When I gor my B6100DT There was 7 out of 8 hoses really bad. After spending a lot of reading here I orderd new hoses and removed the old ones ever so careful...But as described - it was very straight forward to do. My FEL is now ever so myúch stronger, and I am so glad that I found this forum prior buying. It hs helped a lot.
drewscruis
B7100D with FEL and tiller
Sep 9, 2011
21
Eden, NY. usa
if I am doubtful of a hydro line after I've done everything possible to make sure it has no pressure what I do is put a rag around it by either tying it on or i'll use a zip tie so that it is just below the nut on the hose. doesn't work everytime because sometimes there is just no room, but on a loader you should have plenty.
