Reart wheel weights for M9000?
Gb540
44
15
Central US
Wondering if someone could recommend a source for ~300lb rear wheel weights for a M9000.
Has 18.4-30 tires, steel hubs (not cast). Has four factory-made holes in rims measuring approx. 16" on center (from one hole, across middle of rim to opposing hole).
Not having luck finding any universal weights that are remotely close to that, even with the slotted holes. Want to avoid going the "Make 'er fit!" route. ⚒:oops:
Tractor currently has calcium fluid, and we're replacing the rims and tires because both are disintegrating. Would really like to go with weights versus doing this again.
SDT
multiple and various
Apr 15, 2018
3,264
1,060
SE, IN
North States makes weights to fit your tractor.
They make weights for Kubota/others and are less expensive than Kubota weights.
They do not sell retail so you must work through a dealer.
Free shipping to your dealer if total order totals 1,000 Lbs. or more.
Order the bolt kits also.
SDT
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Use anti-freeze and water instead of calcium. Might try the dealer for the cast centers. They weren't that high when I ordered the tractor but getting them after the fact may be a different story.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
RV anti-freeze that is.
Ethelyene-glycol is highly toxic if you cut a tire and this ends up in a water supply.... especially your water well.
JerryMT
Jun 17, 2017
529
153
The Palouse - North Idaho
Wheel Weights - Lonestar Weights
Gb540
44
15
Central US
Will try to track down those weights, worst case will go with some kind of antifreeze.
Other than upfront cost, was always surprised that something non-corrosive like Dowfrost or similar never became the standard for tire fluid. Stuff isn't cheap but neither is replacing rims!
Anyway thanks for the tips.
Turfturd
B7510
May 20, 2021
53
Missouri
I found some wheel weights from a company called Taylor Foundry out of Wichita Falls Texas. I found them on line.
SDT
Apr 15, 2018
3,264
1,060
SE, IN
Taylor Foundry has been making weights for decades.
They, too, make weights for manufacturers (or at least did).
Not sure if they sell retail.
SDT
