Rear tire leaking fluid
pak
24
NE, Wa.
I had been noticing brown blotches around here and there in the snow. Zeroed in on the beet juice is leaking around the interior rim, of the rear tire(ag type). Are there any quick fixes for this? Looks like I will add air as necessary then take the tire/rim in for a cleaning and refill. Ain't it always something?
8,700
If the pressure is low, it will leak, check the pressures, and the pressure should be the same as the without fluid.
Temps affect the pressure drastically when filled with fluid, so keep an eye on it.
pak
24
NE, Wa.
Bingo! This appears to have fixed the leaking. The air pressure was low. Thanks, neighbor.
