Rear PTO Not Working B2400
Wisco608
B2400, hard cab, loader
May 21, 2021
Sun Prairie, Wi
I have a B2400 4wd, Bi-speed Turn and HST.
The mid PTO shaft works.
The rear PTO shaft does not engage. The cab engagement lever has ZERO resistance when sliding it from off to on and on to off. Assumption is the lever inside the housing is broken, as I followed the lever to the housing and everything is connected outside the housing.
So, how do I get inside if I need to? Is it serviceable from the rear cover?
Anyone have a link to a tech manual?
11,292
Sent you a link for the WSM
Look it over and if you have questions or need more just ask.
