D darve5 New member Equipment ZL1801DT, B7300, CIH 275 FWD and several implements May 10, 2009 12 0 0 friendswood tx. May 20, 2009 #1 Went ahead and split the axel housing, only way to do the job. Need to replace the seal on the axel hub. Just in case anyone else has this problem.
D darve5 New member Equipment ZL1801DT, B7300, CIH 275 FWD and several implements May 10, 2009 12 0 0 friendswood tx. May 21, 2009 #2 It's different I will give you that. Found seal here in Houston, should be here tomorrow, if wrong size will get back to you. Gears came off easily,don't see a problem, but thinks for the info.
