RCK 54 23BX mower deck spindle rebuild
Fitter30
Bx1850
Nov 4, 2018
Peace Valley
Searched this forum and could find anything on this. Looked at parts diagram and the shaft and bearings has to be pressed out the bottom. Didn't see any clip holding anything in. Can anyone confirm this.
8,730
To get a proper and complete answer would need more of the mower deck model # as there are 31 different variations of a RCK54 deck.
But I can tell you nothing ever is pressed into place on a kubota, either a clip or a bolt bolts everything in place. ;)
In this case most of the spindles the pulley nut and some sleeves hold everything in place, remove the nut, pulley, washer, and sleeve, then shaft will come out the bottom. ;)
