I've been checking all the bearings, bushings, etc., on my RC60-72 mower deck and noticed that the tension pulley was off line a bit. Upon removing the arm, it was obvious that the spindle welded into the deck was worn to the point where it should be replaced. Has anyone removed this before? It appears that it has been assembled from the bottom and welded in place on the bottom. I'm not going to try to save it, just make a new one to weld back in.
Here are a couple pictures. One from top and one from where I've ground the weld off so far.
thanks
thanks
