R99 fuel troubles
chris142
B7510
Jan 4, 2026
96
51
Apple valley,ca
Anyone else hate this fuel? I understand that it works well in newer electronic controlled engines because they can adjust for the fuel.
It absolutely sucks in older mechanical engines like the idi in my truck and the mechanical diesel in my b7510.
Im currantly trying to locate a station that sells real diesel or even a 20% bio to see if thats any better. So far no luck.
11,540
I don't understand as it has all the makings for great fuel for older engines????
Unlike traditional biodiesel (which contains fatty acid methyl esters), R99 is chemically identical to petroleum diesel and requires zero engine modifications.
Its cleaner, drier, and less prone to water absorption or biological growth than standard biodiesel blends.
It features a higher cetane number than standard ultra-low sulfur diesel (ULSD #2), resulting in smoother, quieter combustion and better cold-start performance.
chris142
B7510
Jan 4, 2026
96
51
Apple valley,ca
Thats what I read about it. But im not the only one with complaints about it. I also have a friend that works at a construction company with lots of older diesel powered equipment. R99 runs fine in the newer 6.7 Fords and x15 cummins. The older mechanical diesels they have dont run well on it either.
11,540
We don't have any R99 or any of the biodiesel mixes here for me to test it out, so I have no first hand experience with it.
Have you tried any addatives with it to see if it improves?
chris142
B7510
Jan 4, 2026
96
51
Apple valley,ca
I have tried power service addative. Same issues. I called one of our local fuel suppliers today. They would not tell me where I can buy diesel made from dinosaurs. Said thats proprietary info.
He did say that real diesel is clear and that yellow or green is a bio blend or R99. Basically told me to check the color at different stations until I find the ones that have what I want.
He also said that if I bought red dye fuel from them that he could not guarantee what the base fuel is.
I stopped on my way home at the shell closest to my house and their diesel is the same color as lemon lime Gatorade so thats definitely not real diesel.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,245
1,224
E.
[QUOTE="chris142, post: 865859, member: 70945"
[/QUOTE]
I don't subscribe to this logic but many believe if you ask your distributor to put red dye into r99 it magically is exactly the same as the off road diesel I use on the farm, or the dyed diesel the construction guys use.
Many believe the only difference between offroad and on road is dye and not the amount of bio or additives added at all. So if this is true, adding red dye to r99 it's the same as offroad diesel???
<< stirring a pot.... stirring the pot>>
chris142
B7510
Jan 4, 2026
96
51
Apple valley,ca
[/QUOTE]
According to the supplier I talked to its the same fuel from the same tank with red coloring being the only difference.
Trash Panda
L2501
Feb 18, 2022
311
287
Wyoming
What symptoms are your unit presenting that is leading you to determine it doesn’t like the R99?
I have yet to encounter a unit that doesn’t run well on it, from HPCR engines down to my dinky little L2501.
Gus1957
M6800, L2501 TLB, BX2370
Dec 17, 2023
92
76
Cobleskill NY
What states are you getting this fuel in? Is it treated for colder winter temperatures? TIA
MapleLeafFarmer
Dec 2, 2019
1,245
1,224
E.
in northern MN my local Cenex only goes up to a 50/50 blend at the pumps but 100% bio is available for delivery to farm and at some select stations. They do not sell R99.
I was told
- their premium diesel contains no bio added but is often not available for sale.
- they treat all for cold weather but at different rates / levels. Premium and No. 1 gets more.
- No. 2 has more "wax" in it but he wouldn't tell me about if its well treated for really cold snaps or what its pour/cloud point is.
- because the local Co-Op only sells B100 for delivery it is treated to the spec. ordered.
cheers and maybe we will see another pump handle added to the pumps in our area too.
L35
Jun 13, 2010
735
845
CT
I was told
I’ve driven as far west as Indiana and never saw any choices like that. South to the gulf too. It’s Like a diesel fuel candy store out there…
chris142
B7510
Jan 4, 2026
96
51
Apple valley,ca
California. They dont treat fuel here for cold as thats not needed. Both my old pickup and the kubota smoke a lot on the r99 and power is way down. Especially my truck. It will not get out of its way and will just blow smoke. Air filters are new on both.
