Quick disconnect replacement 1640 loader
CJN8
B2650HSD, LA534 FEL, Gearmore Box Blade, Bush Hog, Cimmeron Rake
Nov 16, 2013
122
San Diego, CA
Replacing the QDs on my 1640 loader as they are leaking and new o-rings did not help. The hoses are 3/8 npt, what should I look for in a replacement? What ISO series, just the standard agricultural type? On the threads I assume Teflon tape is a no no, just use paste, or? Thanks for the help!
Nate
ipz2222
L235, bx2670
May 30, 2009
1,927
31
38
chickamauga ga usa
Anothe item is "aviation gasket sealer", its available at Auto Zone or Advanced Auto. Brush the threads and let tack dry for an hour or two.
5,166
If you want to replace the couplers with a "better" upgrade go with flat face connectors. When they are disconnected they stay clean unlike the AG connectors.
CJN8
Nov 16, 2013
122
San Diego, CA
Thanks guys, all really good info. Wolfman are the flush style connectors less likely to leak?
