Quick Attach part
woodruffoutdoors
2006 L4330 GST, LA853 FEL, Woods 60" Brush Bull
Mar 10, 2017
22
West Tennessee
I have a quick attach unit on my La853 loader. One of the two handles that raise and lower the pin to lock the attachment into place is missing the bolt and nuts that hold the spring in place and keep tension on the handle. There is an appx. 1/4" hole that looks like a bolt would go in, but there are no threads. In the parts diagram, there is not a replacement bolt, only the nuts and springs. Any idea where to get this piece, and how to attach it? I am assuming it is welded on, and a well broke loose at some point. Thanks for your help!
9,580
look on the plate behind where the hole is, can you see a plug where it's been welded?
If you can that's the pin with the stud, you will need to grind it out and replace the stud and weld it back in.
Check very closely as some pins are just driven in.
Pictures would help.
