M mbu Member Aug 28, 2016 260 4 18 United States May 6, 2019 #1 On a Kubota M7060HDC12 I need to remove its FEL hydraulic control valve. Do I have to drain the tractor's hydraulic oil reserve to do this? Thanks in advance... Last edited: May 6, 2019
Dave_eng Well-known member Lifetime Member Equipment M7040, Nuffield 465 Oct 6, 2012 5,134 936 113 Williamstown Ontario Canada May 6, 2019 #2 mbu said: On a Kubota M7060HDC12 I need to remove its FEL hydraulic control valve. Do I have to drain the tractor's hydraulic oil reserve to do this? Thanks in advance... Click to expand... I looked in my M7040 FEL WSM. It is silent on draining. However, the valve is low and once you start I think you will wish you had drained the fluid. The WSM has many cautions about marking the hoses and getting them back in the correct location otherwise damage. Why do you have to remove the valve? Dave
