Question - B7200HST w B1630 FEL
ttj49
B6100-DT
I recently purchased a B7200HST 4WD with a B1630 loader. I'm in the process of fixing and replacing multiple items. I've got a question about operating the hydraulics.
When the tractor is running and I'm using the FEL the rear lift arms (without weight) will automatically lift up and stay in the up position, fairly tight. They will go down if forced or if weight is applied. Just wondering if this is normal.
There is an implement lowering speed control for the 4WD under the seat, which is basically two nuts, a lock nut and a lowering speed adjustment nut. Should this be adjusted to allow the rear lift to lower? Right now, it will not lower when the tractor is running and there is no weight on the 3-pt.
Thanks
11,559
Let me get this right, even if you lower the 3 point control they won't lower unless loaded?
And if you push them down them they just move back up even thought the 3 point lever is in the down position?
If both are true then yes you have a problem, the 3 point valve is malfuntioning.
ttj49
B6100-DT
Yes, that is correct. They only lower and stay down when the tractor is not running. As soon as I start up the tractor and use the FEL, they come up and stay up even with the 3 pt lever in the down position.
11,559
Can you post some pic's of how the loaders hydraulic lines are connected to the tractor?
ttj49
B6100-DT
I sure can. I'll do it tomorrow. Thanks.
When I picked up the tractor, the 3 pt lift was working well. I stood on the lower links and worked the lift lever up and down several times. It lifted me 220 pounds, without a problem, and lowered without a problem, and seemed to be working okay. While I'm out there tomorrow....I'll turn the lift speed adjustment under the seat and see if this accomplishes anything. The FEL works well, good speed, no jerking, no hesitation, etc....it's just old, and needs some cylinders rebuilt and some hoses.
My first Kubota in 20 years....I'm having a blast with this old thing...!!!
ttj49
B6100-DT
Okay, I got some good photos tonight. Just a bit more information about the 3 pt on my B7200. I have removed everything but the upper lift arms. That is all that is on the rear hydraulic lift at the moment. With the tractor running, I can push down on the lift arms and they will go down, but raise up as soon as I let go. The lift lever does work. It raises the lift arms, with force, but when I push the lift lever to the down position, the lift arms stay up, unless I manually push them down, then raise back up when I let them go.
I have not turned the up/down speed adjustment valve under the seat to "fast" yet to see if the arms would fall on their own when the lift lever is pushed to the lower position. I'm thinking it might be the problem beings there is absolutely no weight on the arms now? I don't know for sure, but it seems the 3 pt may work properly with weight. I do have to push fairly hard on them to lower them....not my full body weight, but about 40 to 50 pounds of pressure I would guess...then they raise back up.
Here are photos of how the FEL is attached to the hydraulics:
LINE - A - PHOTO 1
http://i234.photobucket.com/albums/ee72/timestreasures/Kubota pics/A1_zpsffa15723.jpg
LINE - A - PHOTO 2
http://i234.photobucket.com/albums/ee72/timestreasures/Kubota pics/A2_zps38c6b4fc.jpg
LINE - B - PHOTO 1
http://i234.photobucket.com/albums/ee72/timestreasures/Kubota pics/B1_zps048eae9e.jpg
LINE - B - PHOTO 2
http://i234.photobucket.com/albums/ee72/timestreasures/Kubota pics/B2_zps25043608.jpg
LINE - C - PHOTO 1
http://i234.photobucket.com/albums/ee72/timestreasures/Kubota pics/C1_zps596fbc55.jpg
LINE - C - PHOTO 2
http://i234.photobucket.com/albums/ee72/timestreasures/Kubota pics/C2_zpsf906b9db.jpg
11,559
Where each of the 3 lines connects into the spool valve (loader control) there should be a letter what letters are on each?
Looks like P on line A.
Is that right and what are the other 2?
11,559
Yes, Line A is marked with a P
Line C is marked "OUT"
And I can not find a letter or mark for line B
First things first,
I think the A and B lines are backwards,
Let me do a little more checking, but I'm almost positive that pressure (A) sound be to the front of the tractor, and PB (B) sound be to the rear.;)
11,559
Compare this picture to your spool valve.
I do believe A is in and B is PB and C is out
That being true, then yes the A and B lines are swapped.
A should be to the front and B to the rear.
It might not make a difference when the valve is in neutral, but it's worth changing and making it right.
Next check that the valve in the block is pointed to the side of the tractor, not to the rear (it's a roll pin or pressed pin attached to the valve, that's in the top of the block).
ttj49
B6100-DT
Sounds to me like the 3pt lift valve is bleeding pressure on the lift side.
I installed the lower lift arms, and all components, turned the adjustment for the 3pt lift to activate just a bit faster, and the 3pt is working perfect now. Thanks for checking the connections for me. Now on to rebuilding two right cylinders for the loader...........:eek:
ttj49
B6100-DT
Excellent...!! I will check the setup to the diagram and make the necessary changes....much appreciated...!!
