Put gas in diesel mower
lynnmor
B2601-1
May 3, 2021
1,832
1,629
Red Lion
Though not caused by lightening, the in flight explosion of TWA flight 800 might relate to this (explosive vapor) discussion.
Jet fuel is more like diesel fuel and it will ignite with a wide range of fuel to air ratios. I believe that the flight 800 plane had overheated wiring that passed thru the fuel tank. Hard to believe they build planes that way. 😨
5,188
"Jet fuel"...... is essentially kerosene,.....definitely more volatile than diesel.
I am not aware of any wiring that "passed thru" fuel tanks. There is wiring to power in tank mounted fuel boost pumps.
lynnmor
B2601-1
May 3, 2021
1,832
1,629
Red Lion
The NTSB investigation ended with the adoption of the board's final report on August 23, 2000. The board determined that the probable cause of the TWA 800 accident was:[1]:ā€Š308ā€Š
[An] explosion of the center wing fuel tank (CWT), resulting from ignition of the flammable fuel/air mixture in the tank. The source of ignition energy for the explosion could not be determined with certainty, but, of the sources evaluated by the investigation, the most likely was a short circuit outside of the CWT that allowed excessive voltage to enter it through electrical wiring associated with the fuel quantity indication system.
In addition to the probable cause, the NTSB found the following contributing factors to the accident:[1]:ā€Š308ā€Š
  • The design and certification concept that fuel tank explosions could be prevented solely by precluding all ignition sources.
  • The certification of the Boeing 747 with heat sources located beneath the CWT with no means to reduce the heat transferred into the CWT or to render the fuel tank vapor noncombustible
During the course of its investigation, and in its final report, the NTSB issued 15 safety recommendations, mostly covering fuel tank and wiring-related issues.
4,304
TWA 800 would be a huge Hi-Jack of this thread and is unrelated, IMO, and should be moved to its’ own thread … perhaps in the ā€œOff Topicā€ area. This thread is about putting gasoline into a fuel tank intended for a diesel engine…and has little to do with kerosene/jet-fuel in an airplane.
Link to my theory: https://www.orangetractortalks.com/...fuel-tank-explosion-theory.57890/#post-552598
Tractor Gal
BX23D MLB
Oct 30, 2020
628
278
NC
In a pinch, could kerosene be used instead of diesel. Asking for a friend. :)
Tractor Gal
Boatman
Kubota L2800, Kubota BX1870
Nov 26, 2016
169
54
Mill Spring, NC, US
Tractor Gal
in days of yore on the farm we would run a mix of kero in the winter to prevent gelling. Grand dad always dumped in some 2 stroke oil with the kero for lubricity.
I'd shy away from doing this with modern diesels unless it was a last resort.
Tractor Gal
BX23D MLB
Oct 30, 2020
628
278
NC
In a ā€œpinchā€ yes, I believe so. But be aware it will have even LESS lubricity for your fuel pump than would even ULSD. Vegetable oil would also likely work….but who knows what the cetane level might be.
Picture of friend. :p
Thanks for the reply. I don't intend to do it but I have "an inquiring mind. :)
Tractor Gal
BX23D MLB
Oct 30, 2020
628
278
NC
Thanks for the tip! I still live in the "days of yore." They were the best. :) I don't have any
kerosene but with the fuel situation as it is, one never knows. Thanks again.
5,188
If this discussion of igniting fuel vapor does not fit your comfort zone....... please feel free to stick it elsewhere!
RalphVa
738
322
Charlottesville
Back in the day of simple injection pumps even VW had in their owner's manual to add up to 10 percent gasoline to the diesel for winter conditions.
Benz did that, too, but fairly quickly said not to do it because it forms an explosive vapor in the tank.
lmichael
Kubota G2160
Apr 23, 2021
867
442
Rockford IL area
What REALLY used to get me (because it's so hard to do and you literally have to TRY to be stupid) is putting diesel into a car (modern car). The fuel filler neck on a car is only about 5/8" diameter IIRC but a diesel fuel nozzle is about 1". Yet when I worked at a major rental car place in the local airport here, people managed to be this stupid.
7,743
The diesel nozzle at truck stops are the large diameter for quicker fill ups on large tanks. At stations that primarily serve smaller vehicles have nozzle diameter the same as gas.
lynnmor
B2601-1
May 3, 2021
1,832
1,629
Red Lion
I remember the time that I took my new pickup to a truck stop and watched the truckers laugh at me. Their mouths fell open when I inserted the large nozzle in the newly designed large fuel fill.
lmichael
Kubota G2160
Apr 23, 2021
867
442
Rockford IL area
Actually this is not true. When unleaded gas came in a restrictor was added and been there since. I use an automotive style station that sells diesel where I buy my fuel and there is no way on earth you can get a diesel nozzle into a gas fueled vehicle. Even when the customers who did this were queried as to how. They said they thought something was wrong with the car but they got it in anyway
Boatman
Nov 26, 2016
169
54
Mill Spring, NC, US
Nozzle sizes are:
unleaded 13/16"
auto diesel 15/16"
hi-flo diesel 1 3/16"
That said some vehicles have a flap that requires the exact size nozzle to open the door. For instance I have a 2020 Wrangle diesel, even though the gas nozzle is smaller it won't open the flap. I found this because I needed to put diesel in it with a fuel jug and the flap wouldn't open. there is a special adapter you use with a fuel jug that doesn't have a 15/16" nozzle. My wife has a Mecedes GLK diesel,,,, no flap or restriction,,,, you can use the hi-flo nozzle to fill up.
Snowman7
LX3310 535 loader, LX2980, RB2672, FDR1660
May 20, 2020
406
312
Boyne Falls, MI.
It was a weak attempt at humor. (prior post, I was acting like a dirty old man wanting a pic of a pretty woman….who did not really exist (you were ā€asking for a friendā€)… being a double-entendre …the non existent ā€friendā€ actually being your own pretty self…
… and the next thread a poor attempt at play-on-words….. I.E. ā€œkeroseneā€ being a near homophone of a possible name: ā€œCarol Sceneā€
Sorry. It wasn’t even a near-miss…. was it… :censored:
Made me laugh😊
4,304
Could be possibly a French girl ā€œCarol Seineā€.… :unsure:
