B bgbill New member Equipment BX25 May 12, 2011 30 0 0 BG, Ohio Feb 9, 2013 #1 Do you have to prime a new cylinder, or otherwise how do you purge the air out of the system ? Valve, cylinder, hoses. Bill W.
Bulldog Well-known member Equipment M 9000 DTC, L 3000 DT Mar 30, 2010 5,434 79 48 Rocky Face, Georgia Feb 9, 2013 #2 You should be able to just cycle it in and out a couple of times and it will be ready to work.
L lemontwist New member Equipment L3200 Dec 31, 2012 10 0 0 Bitterroot Valley, MT Feb 11, 2013 #3 The hydraulic system is a loop. The fluid flows thru each valve, then back into the reservoir. So all you need to do is cycle the cylinders to their full extent a few times and the air should be purged.
B Big Kahuna Member Equipment Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880 Dec 23, 2011 375 10 18 Homer City, Pa. Feb 11, 2013 #4 Your reservoir has a breather to let the air out. Big Kauna
