brooster Member Equipment B5200, BX2360, L3940, Z781i KW May 15, 2021 68 8 8 Troy NC Jan 9, 2023 #1 I have ordered my seals for the pump, does fluid need to be drained or the level lowered to do this?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,908 9,128 113 Sandpoint, ID Jan 9, 2023 #2 Nope, it's way above the level, unless you pull the suction line off from the rear.
brooster Member Equipment B5200, BX2360, L3940, Z781i KW May 15, 2021 68 8 8 Troy NC Jan 9, 2023 #3 North Idaho Wolfman said: Nope, it's way above the level, unless you pull the suction line off from the rear. Click to expand... Ok, that’s what I figured but wanted to be sure, thx again
R Russell King Well-known member Lifetime Member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 6,746 2,299 113 Austin, Texas Jan 9, 2023 #4 You may want to stuff something in the hole where the pump is removed from and cover the ends of the pipes. Just to keep crud out… There are probably o-rings between the pipes and the pump so don’t let them get lost.
