Pulley replacement on 60" mower deck
bkusich
mowing, hauling, snow removal
Jun 24, 2010
Freedom, PA
I need to replace the pulley on my mower deck. I cannot remove it though. Any easy way to remove it, other than just plain muscle? The nut holding it in is so tight I cannot budge it!
pat331
L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
Mar 31, 2009
298
Ft. Worth, TX
bkusich, What kind of mower are you working on? I'm sure one of us here on OTT has one like it. Mine is a Bush Hog brand and has right handed threads. It has a washer lock (not right name, but what I call it) that you bend up on the side of the nut to lock it in place. Yours may have left handed threads. Also if you could post a picture or two, it would help. Keep us posted.
KubotaTech
None- I get to play with everyone elses stuff
Apr 1, 2010
185
PA
If it is a Kubota midmount deck, use an air impact gun to loosen the nut.
John C
B7100D, LMC Clipper 400, LMC 4ft Box Blade, NorTrac 47" Tiller
Aug 14, 2009
66
Elizabethtown, KY
Air Impact is the only way to go! I recently had one that I had to use a 3/4 drive impact on in order to get it loose!
