PTO shaft rebuild
poldland
Kubota MX6000, RTR2560, RCR1872, RB1684,QH15,PFL3048, PD15,BB1272
Mar 24, 2023
Wichita, KS
Has anyone rebuilt a PTO shaft. It appears that the one we used with our rototiller and quickhitch was too short and would like to rebuild the shaft to be longer.
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
148
59
Central, ME,USA
I think you will find just buying a new shaft and cut it to the right length will be the best rout, especially since yours is too short. Tractor supply, granger or just look on line they aren't that expensive.
3,093
You may be able to get the existing shaft fixed by cutting off the ends and welding on new shaft halves. If you don’t have the skills a drive line shop may be able to do it.
see this link for details
may be cheaper to just buy the whole thing if you can figure out what ends you need. I imagine there are a few different types to choose from.
you may be able to find the correct information about the shaft in the implement’s owners manual
kubotafreak
Sep 20, 2018
1,049
402
Arkansas, US
No welding needed you just need to buy a new piece of pto inner, or outer tube. They are installed by drilling a hole with roll pin. If your lucky the shield will still fit if not the shield may be too short too. If the shield is too short you may be cheaper to just buy a new shaft and keep this one for parts.
