I have a BX 2360 that is having some PTO issues. The tractor runs fine...forward and reverse and the bucket works. The problem I'm having is with the lower and rear PTO's. They don't run at full speed...they turn slowly when engaged, but not fast enough to cut grass.
I took it to our Kubota dealer who told me that the "PTO" was bad and would need to be replaced...to the tune of about $2600. Not having the cash and being pretty handy with a wrench, I decided to "break the tractor in half" and fix it myself. I downloaded the Service Manual for my tractor and proceeded to tear it down.
I got the Transaxle out and opened it up, but can't find any problems with the PTO gears (or any gears). A buddy of mine said it could be something with the hydraulic system not getting enough pressure to engage the PTO shafts at full throttle. Is there a separate hydraulic system for the PTO? Because the bucket works fine. I pulled the high pressure valves out of the center section of the oil cooler and they look fine. I couldn't find any bad seal or gaskets...I will replace them with new ones when I re-assemble the unit.
The PTO Clutch Assy "looks" OK...but I'm not the expert...and I'm reluctant to pull it apart without the clutch spring compressor tool.
What am I missing? What can I check for?
Thanks in advance for your help!
Mike
Mike
