Pto on front d722e??????
jshort
D722e engine
May 31, 2023
West virginia
I have a d722e with splined crack shaft I'm wanting to put a double pulley on it to power a pto electric clutch under it my single groove pulley on it is not tapped to bolt another to it any ideas
9,844
Coupling and shaft off the front of the crank pulley to a carrier bearing holding the electric clutch.
BX23-S,57 A-C D-14,
5,959
ok... remove crankshaft pulley and have a 'machine shop' weld on the 2nd pulley.
they could use a stub 'shaft' to center the 2 pulleys,then a few tack welds to secure them
I've done 'triples' this way )
or
they could just drill 4 holes through the pair and secure with nuts,bolts and spacers. this allows you to go back to 'stock' if required.
9,844
Post a picture of the crank pulley as there are many different styles.
9,844
Yea that style of pulley is not very easy to adapt anything to it.
