PTO not disengaging when it should
MotorCityBear
L3901
Aug 3, 2019
23
Blairsville, GA
I have an L3901 with approximately 100 hours that has developed an issue where the PTO doesn’t disengage When I move the I talked to my dealer and did a search here and the “solution” appears to be spraying lubricant into the PTO cable. I have fine that a few times but the issue reappears a few weeks later. Has anyone come up with a better solution?
5,515
2,231
follow the cable down to where it attaches to the transmission
drench the return spring at the end of the cable with your favorite lubricant wd40 kroil pblaster whatever you have it don't matter. Work the lever back & forth a few times. Should free right up.
BigG
Sep 14, 2018
1,953
775
West Central,FL
Are you storing the tractor outside? Perhaps every time you get on the tractor you need to engage/disengage the PTO.
Fido Farms
L3901, 35 Massey
May 27, 2018
119
Try checking the adjustment on the pto cable. With the tractor off and the pto disengaged do this. Rotate the pto shaft by hand and while your moving the shaft slowly try to engage the pto using the lever. See how much play you have before the pto cam start to lock up/click. I may just be set to close. Check the manual to compare/set the pto cable. It may solve your issue.
MotorCityBear
L3901
Aug 3, 2019
23
Blairsville, GA
I will check the cable tension this weekend. Thanks for the help.
kubotafreak
Sep 20, 2018
1,049
402
Arkansas, US
May or may not be related, but be sure to idle down before shutting down pto implements. They can burn out the brake for the clutch in short order.
