Pto in B2320 max engine rpm
8Bitmix
B2320
Nov 12, 2016
On the b2320 there is a pto orange line at 1540 my father states that's the max rpm it should be run at an explanation would be great
7,738
Re: Urg pto in b2320 father says it is the max rpm help please
A standard Power Take Off RPM is 540. When your indicator is at that mark that is when your implement is functioning at is best.
You can run the RPM lower or higher and your tractor will not explode!
Best advise I can give is to read your owner's manual.
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
Your tractor may not blow up but the implement may if the pto rpms exceed their rating.
Like d2cat said, read the manual for the tractor and the implement.
Ray
