have a b2301 with a 60" mid mount deck, with the pto engaged and the deck in the up position it runs and sounds as it should, as soon as I lower the deck ,again with the pto on, I get a very bad noise as I move forward and start mowing the noise stops. I took the belt loose and engaged the pto and I get the noise when I lower the deck as before, I raise the deck the noise stops. So I replaced all the bearings and seals in the gearbox I still have the noise as before.
Thinking driveshaft ? A ideas? I cant find any play in the driveshaft.
Thanks
Thanks
