Propeller shaft seal (L3600)
coderbond
Kubota L3600
Mar 16, 2014
20
Selah, WA
Anybody had to fix a propeller shaft seal? Can I just separate the tractor at the bell housing and fix it from the clutch side or do I need to separate the transmission from the mid case?
I had the whole mid case out and was fixing the hydraulic clutch (GST) type and apparently knocked the seal loose during reassembly.
11,292
You'll need to separate it at the bell housing to get to the seal on yours.
There is 2 seals (#70) 09500-25388 and 2 Orings (#35) TA040-82180
