Problems with moving shuttle shift
graybellplumb
Kubota l355 ss
May 27, 2023
Myakka city Fl
When I pull the lever it takes awhile for it to lift. Once it lifts up then the tractor moves. Any ideas? I think its hydraulic related. The 3 point will engage if the throttle is high. The lever to the shuttle shift does move,but it won't engage the axle. Its 1984. Just had clutch replaced.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
684
292
Herald Calif.
Have you serviced the hydraulic oil and cleaned the filter. Are you saying the tractor will not move? Does the PTO work?
9,580
Yes. There is hydraulic fluid leaking into the motor.
Then you have an issue with the hydraulic system.
Bad pump shaft seals or bad pump and or dead headed system.
You need to fix the pump seal and test pressures.
9,580
Lets go back to your first statement.
"When I pull the lever it takes a while for it to lift"
Are you talking about the three point or the shuttle lever?
"Once it lifts up then the tractor moves"
Are you talking about the shuttle lever or the three point?
9,580
Is the hydraulic system stock or are there any added valves or added loader, running off the hydraulics?
