Primer Crimp Removal
bucktail
Jun 13, 2016
1,297
220
MN
I'm in the market for some once fired brass in .223. Much of it comes with a crimped primer that needs to be removed before you can remove the primer. A 5 minute goggle search shows an RCBS tool for $20, but it needs to be run by a $200 prep center that I don't have.
I haven't messed with the crimps before. Is there a hand tool that removes the crimp without causing carpel tunnel disorder or one that chucks into a drill that will remove the crimps or should I just buy un-crimped brass?
5,573
Just lube the case, run it through you decapping die, and the once the old primer is out, just use your deburring tool. I have done this to bunches of mill issue 3006, 7.62 and 5.56. One word of caution if you have a single stage press use it, and pick up a supply of de priming pins ,yes you will break some
SidecarFlip
Banned
563
First off, buy a dedicated de-priming die like a Lee or RCBS or Lyman and never break a pin again. Secondly de prime and then cut the pocket with the RCBS or Lyman or whatever case mouth tool. I chuck mine in a lathe (I have 4 in the shop and do them that way....) I use a Little Crow case trimmer to size the cases (223). Don't size anything else because I use bushing dies and bump the shoulders back instead....
RCBS makes a nice lever pocket swaging tool and so does Dillon but the RCBS tool is cheaper by about 10 bucks. Finally Frankfort Arsenal has just come out with a lever swager fr even less.
bucktail
Jun 13, 2016
1,297
220
MN
I do have an RCBS depriming die. Was going to ask about that until I read your response. I think that my primer clean up tool is Lyman. I can upgrade from that if the case chamfer tool and primer clean up won't get it.
twomany
B7200
Jul 10, 2017
793
139
Vermont
I've never heard of removing the stakes BEFORE removing the spent primer.
Maybe I read the original post text incorrectly.
Ping
BX2370-1
Dec 25, 2018
368
382
Troy, Ohio
No, I read it the same way. Crimp removed BEFORE deprime.
I just pop em out while resizing and run a pocket uniform afterwards.
armylifer
Mar 26, 2013
2,326
1,082
Thurston County, WA
I have been doing it exactly the way that Skeets described for more than 45 years. I started doing it that way because of cost and just continued doing it the same way out of habit.
SidecarFlip
Banned
563
Not that I've looked lately but I believe I have a couple thousand FL resized and prepped and primed 223 cases in the armory that could be charged and loaded when I want to. Not that I do. Got a couple thousand loaded in ammo cans. I usually buy Hornady 55 grain Spire Points in bulk (2000 at a time) and load them with H322 or H335.
223's good for plinking and not much else.
Beaudeane
MX5800, LA1065, BH92, BB72X, RT72.40, EA 60 in grapple, county line auger
Mar 9, 2018
127
Dalton, Ga
Remove the primer first then swage the primer pocket. I have the Dillon swagger but like someone said if Frankfort Arsenal is making one now, I’d have one if I didn’t already have the Dillon. That’s based on other frankford items I’m very happy with ie: their brass tumbler with the stainless pins and their brass dryer. Swage or ream the primer pocket after primer removal is the way the books say do it. I use the Lee universal depriming die for military brass and also like stated above, get extra primer pins because u will break some and some u just can’t punch out at all is my experience. Maybe 1 in 500-800 that won’t press out of the ones I’ve done. Btw, military brass is way cheaper to start with if u have the tools to prep it, and don’t mind the little extra time it takes rather than buying new. Last few batches I bought came from CA shipped to GA for a small percentage of what I could buy new at my local shops. Once it’s swaged u don’t have to do it on your second reload either, just clean, resize, trim and reload
