Post hole digger
Rubicon1000
BX2670
Apr 6, 2016
Indianapolis
Hi everyone. I recently bought a b2301 and I need to know if I can use a standard auger or do I need one of the smaller ones.
My dealer said that any size will work on the b series but before I buy one I just wanted to ask you guys.
I know the bx uses the smaller one but I'm hoping a standard size will work.
Thanks for any help, Dan
4,599
What is a "standard size"? Do you mean the attach point size or the diameter of the hole size?
5,979
before you buy....
how many holes ?
just a one time use, but nice to have ?
It may be cheaper to RENT a standalone PHD machine, even have someone bore the holes for you.
In my case, it was cheaper and faster to have a pro come bore the 16 holes, instead of me driving 3 miles to get the free-to-use PHD, and then figure out how to use it.
just something to consider.
  • Dislike
old and tired
1,919
1,297
The B will use a regular PHD... if you have Indust./R4 tires it might drag the ground a little (ag/R1 tires have more height to them).
For what it's worth. My PHD is the least used implement that I have... Such a pain in the butt to hook up, that unless I'm doing a dozen holes or more, I'll dig them by hand and will be faster at the total time (than hooking and unloading the PHD).
4,599
Everyone has a reason for why they want/need a tool so I agree, you gotta weigh the pros and cons, like convenience/time/money, or whatever, However;
The last time I rented a gas powered PHD it beat the sh1t out of me and my buddy (who is 20 years younger and in great shape).
Then we proceeded to get it stuck about 7/8 of the way to it's max depth, and it took us 3 hours to unstick that mother%**king thing.
We had 16 holes to dig and we got 1 and 7/8ths of one done before he called a guy to come do it. (this was pre-tractor for me).
Never will I do that again. I'll take the time to hook it up and I agree, they are a PITA to hook up.
That being said.....I now have one that mostly sits there looking pretty but it's ready to go if I need it.
Paul
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,758
2,202
Western MT
A pull behind post hole digger works pretty well. It's a bit of pain to get from the rental area.
As far as the tractor goes, I think it depends on how much lift you have with the lift arms whether the standard size will work. Maybe someone here has a B2301 or B2601 and uses one.
What model numbers are you comparing?
ajschnitzelbank
Aug 24, 2021
268
669
Rensselaer County NY
I had a “County Line” (Tractor Supply brand) on my B2301. Just fit; if my memory serves lifted up there was a few inches of ground clearance. My soil is so rocky that I found it pretty much useless and sold it. I thought the TSC one seemed pretty well made, at least at that time. If I had different soil I’d buy it again.
Rubicon1000
BX2670
Apr 6, 2016
Indianapolis
Thanks guys. I've had five kubotas over the years and I will be using it plenty. Just wanted to know if it would fit. I appreciate the answers.
Rubicon1000
BX2670
Apr 6, 2016
Indianapolis
Thanks for the picture. Exactly what I needed to know
3,328
I see a couple people mentioning hooking up a PHD is a pain. Why is that?
Never had an issue with my PHD on my B2910. Easy for me. What is the issue?
I store mine hanging from a chain. Perhaps that is the difference?
Curious…
edit: I have 14" & 9" augers for mine. Glad I have both.
2,584
The PHD is generally laying on the ground and heavy enough that they can be difficult to get attached. Using a stand or hanging them eliminates that problem.
some people just drill a hole and then leave the auger to hold up the PHD
bearskinner
Sep 1, 2014
926
241
N. Idaho
I don’t use mine that often 3 or 4 times a year. It’s great for planting trees too. It’s well worth having one here, and by hanging it off the side of my wood shed, I can back up to it, and hook up quickly. Same for unloading. Hang it with the auger touching the ground. I leave the pins in it, and put a strap on the driveshaft to keep it up off the ground.
bearskinner
Sep 1, 2014
926
241
N. Idaho
It fits other tractors too. My neighbor poking holes for trees, with his tractor
Botamon
Mar 26, 2018
432
836
Winnemucca, Nevada
Curious…
This was my solution also. My PHD is ancient - and very heavy. So I built a tall frame and the PHD hangs on two chains from that frame. The chains are attached to all-thread with cranks welded to them so I can adjust the 3 point hitch attachment points up and down; with the swing allowed by the chains and the up and down front and rear adjustments now I can mount the PHD to the 3 point hitch without too much cussing.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,558
3,852
PEI Canada
I have a PD25 with 9" & 24" augers. I picked up the Landpride stand and fastened it to a pallet for easier hook up and storage.
