Poll: Cost to add water & anti-freeze to tires
pbarnett
M7450, L3010 & BX25
May 29, 2013
Brookhaven, MS, USA
What would be a fair charge for adding water & antifreeze to the rear tires of my M7040?
My local Kubota dealer just charged me the following:
$195.00 - (1) Install tire ballast (water/antifreeze solution)
$ 48.32 - (4) Miscellaneous Parts
$ 17.03 - Tax
$260.35 - TOTAL
I feel as though I have just been run over by my M7040
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I would say they put at least 5 gallons of anti-freeze per side. So if you were lucky it would cost $100 - $150 just for anti-freeze. If they used more the cost would be higher so I guess for them doing all the work it wasn't that bad.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,222
144
Coyote Flats,Texas
Rather than pay dealer I do it myself. I've filled many tires with liquid years back. All it takes is a jack,valve stem/water hose adapter,funnel for antifreeze and a little time. "Nothing to it,a baby could do if you held them up to it"
Breeze
L3700, Box Grader, 60" Bush Hog, Rear Grader Blade, York Rake, Boom Pole.
Dec 24, 2010
149
Virgin Islands
Ethylene Glycol (Anti-Freeze) is both sweet and very poisonous. Just a taste is sufficient to seriously injure or kill a small child, dog or cat.
I would be hesitant to use this in tires which are prone to leaks. There are good alternatives available.
fuzzydawg
L3400 HST
Oct 11, 2011
Bluffton, MO
I spent about $100 for 16 jugs of antifreeze (got O'Reilly house brand on sale) and put 16 gallons of 50/50 water/antifreeze mix in each rear 11.2 X 24 ag tire. Did it myself, easy job but took a couple hours (including time for a beer break, of course). Plus I spent maybe $5 on the hose-to-valve-stem connector.
So, it looks like your cost wasn't real extreme. Back out the $17 taxes, and you paid $243 for something you could have done yourself for around $105. Difference of $138 is presumably labor. Maybe an hour and a half at $90 per hour?
I'd say you did okay.
Update: re-read the thread and saw "2 gallons per tire". Assuming they also put 2 gallons of water in there on each side, that's only 4 gallons per tire. Hardly worth the effort. Changes my opinion to "yeah, too high"!
3,804
IM with you dawg cheapest stuff I could find mixed 50/50 also if you look around some you might find a salvage yard they will let you have the anti freeze for almost nothing,,We did that for a friend took 2 55gal drums and filled them,,, the yards have to pay to have the stuff hauled away I think he gave a buck a gallon
