We had our first significant snowfall of the year: about 3.5 inches, which I know just counts as a dusting for some of you. I live on a hilly one mile dead end road where the homeowners association pays for it to be plowed, but we're cheap, so it sometimes take the guy a while to get to us.
It was slick today, and with the morning off, I did what I could with my FEL and box blade. That combination will work fine for my driveway, and a few of my neighbors, but I stopped on the way to work at the local tractor store and bought a used 5' rear blade (though I'm sad to say it's green), which I'll use some on the road. (Wish I could take on the job and be the one to get paid for it, but I'm not consistently available, and it would take me far longer than the guy with the big pickup plow.)
Here's my question: Am I ok running up and down the hills in high range and 4wd while plowing snow with my little BX? Top speed is less than 8 mph, and it doesn't feel unsafe to be plowing on the road at that speed. But I don't want to overtax my machine.
One reason I'm concerned is that today I heard a slight change in the sound from the transmission, and at the same time it seemed to be down on power. This was after I'd been out for an hour or so, doing a few of my neighbors' drives, and then hitting the road at high speed. Taking it out of 4wd seemed to stop the strange noise, and I kept it low range for a while too. Later, high range 4wd seemed normal, so not sure what was going on. Maybe some slight binding in the 4wd linkage? Or maybe the HST getting too hot? (Ambient temps were right around freezing--not that cold, but cold enough that I didn't think I'd need to worry about anything overheating. Fluid levels in transmission and front axle are good, and HST fan is intact.)
I've never run in 4wd and high range before today, and don't see any time I would other than plowing snow on the road. But I absolutely needed the 4wd to keep moving. Is this within normal operating parameters? Or am I pushing it?
