Plow Blade for L245DT
James42384
L245DT
Sep 28, 2018
Edgewater
Anyone have or used a KUFD210 push blade setup for a L245DT?
Any aftermarket options you***8217;ve gone with for pushing snow?
Thanks!
James42384
L245DT
Sep 28, 2018
Edgewater
I do have a FEL. I have a long straight driveway that I’d like to plow this winter. Scooping it in the bucket is an option but I think it will take me much longer than pushing it with a plow.
8,786
The reason I asked if you had a FEL, you can put a blade in place of the bucket, it's a better option than removing the loader (which can be a difficult task on older models) and using a dedicated snowplow.
If you want it to work even easier and quicker then put an SSQA adapter on the loader then it opens a ton of possibilities ;).
James42384
L245DT
Sep 28, 2018
Edgewater
How do you put a blade in place of the bucket? Is that an aftermarket option?
8,786
There is three easy ways to do it.
Get a bolt on blade.
Get a pin on unit that will pin on in place of the bucket.
Or better yet do as I said earlier and get a SSQA blade and a SSQA adapter for your FEL.
The first 2 options you will probably have to have someone custom make the units.
The third option would be available from several sources at a reasonable cost.
Here is examples of what I'm talking about:
https://www.amazon.com/Conversion-A...K30ZWA753YJ&psc=1&refRID=A0GZF5VMAK30ZWA753YJ
https://www.amazon.com/Titan-Attachments-Adapter-Spacer-Brackets/dp/B0115YN1RS
https://www.everythingattachments.c...c-Angle-For-Tractors-p/wrl-front-blade-ha.htm
shootem604
Apr 23, 2018
874
British Columbia
There was a Kubota front plow for the L245DT, but it doesn't fit if you also have the FEL. Besides, NIW's advice is better.
I actually found one a year ago that I was thinking of fitting to a L225 I had, but I sold that tractor.
