pin style quick attchment FEL bent ??
KUBOTA4900
KUBOTA M4900SDC & LA100C LOADER,PALLET FORKS,BRUSH HOG BOX SCRAPER 3PT HITCH
Feb 3, 2013
65
durango colo la plata co
I have a pin style quick attachment for my implements front loader forks basket lift I have bent the face part on the loader end and have heard you can try and fix with block of wood being placed in areas of the front hydraulic cylinders ?? please help
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Check the air pressure in rear tires. These types of situations sometimes are not something bent, but lack of proper air in tires exhibiting as uneven front equipment levels.
8,826
If the landing pads are out of time, you can reset them with a block of wood or a chain and a big tree.;)
quazz
L3800 and Z411
Jan 6, 2014
296
Rockley, NS
Mine was bent from the factory. The first time I tried to put a new implement on it wouldn't go. I finally forced it and the dealership sent a guy over and they saw that it was defective and replaced it.
RONB83530
L5740
Jan 5, 2017
10
United States
Wolfman, i realize this is from the past...but can you elaborate on this please? What do you mean by out of time....and please explain what you have in mind to fix it?
thanks, grangeville.
8,826
If the landing pads are not at the same point in the stroke, So one is farther out than the other, it makes it very hard to hook up implements, even if it's off a little bit.
It's fairly easy to fix, one way to do it is to chain the leading pad back to the tractor then roll the pads forward till they are in alignment.
Note: If it's extreme it might require cutting the welds on the cross tube of the hitch, realigning it and then re welding the cross tube.
RONB83530
L5740
Jan 5, 2017
10
United States
Wolfman, thank you for your answer...I follow your postings and advice to others.
I bought a used Grand L5740 with a LA 854 loader..and a new bucket on it...
everything looked great until I removed the bucket and tried to put the snow plow on....then I noticed I had all sorts of issues doing that...
Soon with the nothing attached and the boom up about 4 feet and with the use of 2 4ft. levels...I was able to determine that the right pad is about 1to 1 1/4 inch further forward then the left pad...and that difference is the same thru the entire cycle. it is a pain to change implements....I was a bit reluctant to start ramming and jamming for fear of wrinkling something...or doing worse damage...
I have plenty of trees and lots of chain...I just worried about bending something...i am not certain at what point...do you go beyond the chain and the trees to a shop where someone may know more than me...
as always thanks for your efforts here.
outpost22
L3800, RTV500
Feb 20, 2017
24
Eagle Point, Oregon, USA
Ron
Is the Quick Attach system physically bent or are the hydraulic cylinders "out of time"? If they are "out of sychronization", you might try bleeding the hydraulic valve at the fitting. Mine are "in time" so I haven't had this problem. If the actual coupler is bent, then it becomes a "gorilla fix".
8,826
Ron
You can't "bleed" the system to get them timed, there is a metal cross bar that times them. ;)
RONB83530
L5740
Jan 5, 2017
10
United States
Thanks, Gentlemen.
A friend has suggested cutting that bar---attaching a sleeve---aligning the landing pads properly and then welding the bar solid ----since the difference is consistent thru the entire cycle----that suggestion seems to have some merit.
8,826
If it's only off slightly, try chaining back the leading mount and use the hydraulics to roll the lagging mount back into alignment before you cut it apart. ;)
scdeerslayer
MX5200DT
May 23, 2016
434
SC
Thanks, Gentlemen.
That's kind of my thought if I ever need to do this, except that one side will be just a shear bolt. It doesn't need to be all that strong because it's really only to keep both sides aligned when there's no attachment on. With the shear bolt subsequent repairs should only take a couple of minutes.
RONB83530
L5740
Jan 5, 2017
10
United States
Thanks to all... I took your advice Wolf....cut the welds...rewelded the errant side...took 30 minutes cost $75. works perfectly...
not sure how the hell they let stuff like that get out of the factory..
hope you all are having a great but busy summer
ron b 83530 Idaho
