Part numbers need for b8200
Codyrapoza
B8200 4wd hst
Apr 25, 2020
26
Ogden, utah
Hi I’m trying to peice together a nice clean way to add rear hydraulic controls and front too if I ever find a loader. Loader would be a bf300. Pics and or part numbers for this stuff would be awesome, thanks!
kenrevo
B9200
Oct 28, 2019
62
19
MA
I have a B9200 and just finish researching adding rear remotes a couple months ago. It is basically the as the B8200 but is a little larger and more powerful. I found the Kubota B5550 or B5550a trencher required rear remotes and Kubota had a OEM solution for some of these older tractors that never had an option for rear remotes.
I attached the excerpts from the trencher manual of the layout and part numbers but before you get your hopes up all of these parts have been discontinued by Kubota. I got lucky and found some fittings I needed for my setup on eBay sold as new-old-stock.
If you can't find the fittings you need, you can use the power beyond circuit off the distribution block or loader valve and run hoses to the back of the tractor.
The loader uses the distribution block on the right side of tractor for the loader. This is documented as it's the standard way to connect the loader.
Codyrapoza
B8200 4wd hst
Apr 25, 2020
26
Ogden, utah
Perfect, is the part number B2016 for this kit? Got a pic of it on the tractor? I wonder why my kubota dealer can’t find this type of info, it’s like because I don’t have a brand new 30k tractor they don’t want to spend the time when I ask them about the factory rear remote option that the wsm clearly has in it and was available.
