I am referring to the block under the right side floor board where the hoses connect for the loader. On the bottom side of the block there is a valve? What is the correct order of assembling the "shims". There is a washer that goes in first and then I have a "shim pack". One shim has a hole in it and the other does not. What order do these go in? Messiks it show a stack labeled as 120 but it does not identify with or without hole?
Kubota L3600 DT with LA680 loader. T10600 Outlet block
