Outlet block for the loader hydraulics. Valve reassembly.
Nickk
L3600 Kubota
Jan 24, 2023
73
Auburn, Indiana
I am referring to the block under the right side floor board where the hoses connect for the loader. On the bottom side of the block there is a valve? What is the correct order of assembling the "shims". There is a washer that goes in first and then I have a "shim pack". One shim has a hole in it and the other does not. What order do these go in? Messiks it show a stack labeled as 120 but it does not identify with or without hole?
Kubota L3600 DT with LA680 loader. T10600 Outlet block
2,048
I am not able to answer the question but suggest you try to post some pictures of the valve port and the shims and the valve (which may be the pressure relief valve?).
You may be able to find some service manual (AKA work shop manual, WSM) at Kubotabooks dot com
5,242
If it matters I would assume the one with out the hole goes against the poppet.
Edit: lookingvat the parts diagram I am guessing the "shim" with vhole in it is actually part number 130 - "washer, plain"
