Out of cab PTO use L4060 LE
ACDII
Oct 21, 2021
690
432
Illinois
I tried searching but the search function states, disregarded PTO because too short, so have to post this question though it has probably been asked a LOT.
I think, but not sure that I need to buy a switch in order to use the PTO when not on the seat. I engaged it the other day to check the pump for the sprayer to make sure it works before investing time into it and the engine quit the moment my butt left the seat. I didn't see in the manual how to use the PTO for stationary equipment either.
So how does it engage? and do I need the switch and if someone has the part number, appreciated!
I just spent 2 Saturdays rebuilding the sprayer, replaced both tires and tubes and before I even got them dirty drilled a hole in one of them! DOH. I was going to fill and test it, but then remembered, I can't leave the seat.
notaz3
98
97
ID
The LE does not have the PTO switch under the seat. One of the things they left out, along with mirrors, front work lights, cruse control, and rear 12 volt outlet.
Switch part number is 32771-47840. The wiring is there, just need switch and screw.
ACDII
Oct 21, 2021
690
432
Illinois
Thats what I thought. Going to get the switch ordered. I would from Messicks, but my local dealer is the same price without added shipping.
notaz3
98
97
ID
Messicks is great for finding information; however, like you, I find my local dealer is same or very close to same price.
3,401
And probably cheaper if you add in Messicks' shipping charges, at least if you get the part added to the local dealer's normal order, and do not special order it individually.
ACDII
Oct 21, 2021
690
432
Illinois
Agreed. The shipping can be an issue with some stuff, but if they have it in stock and local takes more than a week, sometimes it's worth the cost of shipping to get it sooner.
PortTackFarm
L3560 LE (ROP's) w/ LA805 FEL, LP RCF 2072, BB2572 and WoodMaxx WM-8H
Jul 2, 2021
147
179
The Ville and The Farm (KY)
Thanks for listing the part number. I want to add that to my tractor. I assume it's the same part number for the L3560 LE ROPS as well. While we're at it, does anyone off hand know the part number to add the Cruise Control switch?
ACDII
Oct 21, 2021
690
432
Illinois
TD350-55210
I think the price went up quite a bit, I think it used to be $56, now its nearly $100.
4,249
The thing I’ve found about Messicks and shipping is that Messicks doesn’t charge shipping….. UPS/FedEx does.
But Messicks DOES give out free technical support when you call them (Doug in Service) about the problems you’re having installing the part you bought. When that part installation is a puzzle and your local dealer has never done it but tries to “make it up” and act like he knows what he’s saying and you screw-up the new part trying to do it the local dealers’ way…. Doug at Messicks will explain the RIGHT way/EASY way to do it…. and that makes the shipping from Messicks worth more than GOLD.
DougR@sc
L4060 LE HST Cab
Aug 1, 2024
Aiken SC
I ordered the part number listed but it seems to be a replacement to the operator present switch that exists. I need a switch to bypass the operator present in the seat. This will allow me to use the PTO driven sprayer when I want to be out of the cab and to use the hand sprayer. TIA
ACDII
Oct 21, 2021
690
432
Illinois
This is the PTO switch
You flip the seat up, then engage the PTO. It mounts on the right side of the seat near the PTO controls.
ACDII
Oct 21, 2021
690
432
Illinois
I have been wondering about that switch though, and some day plan to test out my theory. That is a two position switch, Clutch on when sitting, pin all the way depressed. Clutch on when fully extended, seat up. In between it breaks the circuit and disables the PTO. If I were to remove the switch, just lay it on the side plugged in, would it work regardless if on the seat or not? Some times I need the PTO to run on and off the seat.
Would also like to bypass the sitting on seat while moving switch, there are times while traveling that the motor died on me because the rough road bounced me off the seat. I know, seat belt will prevent that, but I have had the seat belt bruise me up from it locking tight from the bouncing.
muttbarker
Kubota L4060 HST, Snowblower, FEL, Rear Blade, 60" Grapple, 6' Bush Hog, Forks
Jan 24, 2022
96
71
Oakley, Utah
So, I have the Kubota L4060HSTC-LE tractor (from 12/2021) and while I love it I am facing the issue that started this thread. Running the PTO while not seated. I am trying to use the PTO to run a chipper and would prefer to not just dump a sandbag on the seat. I know that the LE did not include this ability and when I first started reading the thread I thought I needed part 32771-47840. But after I got it and poked around I believe that this is present in the seat assembly already and does nothing to allow the PTO to run with the seat flipped forward. So, I am thinking that I just need to return that part. Does that sound correct?
I am now looking to understand how to 1) add that functionality, or 2) use something like the other switch mentioned above [TD170-47920]. That would appear to be the missing upgrade that I need. If I am reading this thread right then I need to get that switch and plug it in to add that missing capability. Is that correct, and if so does anyone have any guidance on where / what it would plug into? I searched for diagrams but came up empty.
Any advice, or pretty pictures would be greatly appreciated.
Kevin
Oakley, UT
ACDII
Oct 21, 2021
690
432
Illinois
Kevin
Oakley, UT
47920 is the correct part for the PTO. It attaches to the side of the seat on the PTO side. The other one I believe that you have is the kill switch for when you leave the seat while in motion. I HATE that switch and want it GONE! Whenever I am trying to line up my forks I have to lean forward to see over the hood, which gets me off the seat and if I touch the pedal in any way, DEAD ENGINE! GRRR.
5,576
I have never seen your set up, but is there a reason you cant use a “zip tie” to close the switch(s)?
I think I used a piece of “safety wire” to close my switch. (Ironic ain’t it :unsure: )
KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260, ZG222
Jan 9, 2022
182
384
NW Arkansas
Arkansas chrome—duct tape. Matches the gray too.
ACDII
Oct 21, 2021
690
432
Illinois
It's not something at the forefront of my gitrdone list. Only time I even think about it is when the butt leaves the seat while in motion, then I get occupied with other things and totally forget to look into it.
Like this morning, have to get a belt off my car to get a replacement, come downstairs to grab something and find water on the floor from the wall leaking, again, so much for stop leak. Crappy concrete job where the new wall met the old wall. 43* this morning so the snow is melting, it's raining, and the water poolng right at the corner where teh seam is. Found another one just above the waste pipe going to the septic too.
Now, what was question?
