Operator Presence Error
bbxlr8
Mar 29, 2021
440
303
Eastern PA
Not the same model but initially mine was super sensitive over bumps on trails etc.
Drove me crazy enough to wire-tie it after I figured it out ;)
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
The last time I had seat switch trouble I was moving snow. Some got under the seat somehow and kept it from going all the way down. I cleared the snow under the seat and that did it. The only other time the rod under the seat on which it pivots up had come loose on one end allowing only intermittent operation of the switch. I put the rod back and replaced a washer and cotter key - problem solved.
bbxlr8
Mar 29, 2021
440
303
Eastern PA
Don't know about the OP regarding the cold, but that if what I was talking about. Unweighting the seat briefly "burped" the engine with power loss.
Conda71
L3302
May 4, 2022
Wickham, NB
Hi All,
Thanks for the info. The L02 seats have the sensor mounted directly in the seat, I wish I had a lever that I could wiretie down. When the seat gets cold the sensor can no longer sense someone sitting in the seat.
Crash277
BX23S
Jan 17, 2021
844
621
i know on my 23s when snow blowing backwards i trip that sensor all the time because i slide forward a bit so i can turn sideways so i dont have enough weight towards the back of the seat
