Open Center versus Tandem valve
TexasDave
MX4700, ZD326, LTX 1140, BX2370
Jun 15, 2014
15
McDade tx USA
Can't believe I can't find this question answered somewhere on the net!!
Going to install a third-function circuit on the front of my MX4700 to operate a root grapple. Being frugal (cheap?:)), I am trying to economize by buying the individual components versus a kit.
Here's my understanding:
Tapping into the power-beyond circuit, you need an open-center valve. Or a tandem valve. Both flow freely from P to T in the center position (three-position valve). But the OC valve connects A to B when centered, allowing the grapple to be moved, which wouldn't hold the load unless the switch was held in the "close" position. The tandem valve does NOT connect A to B in center position, so the grapple would hold the load if the switch was released.
I'm looking at a three-position tandem valve such as a Northman 22305-2306 or similar.
Do I have this right?
Thanks in advance!
Dave
Kennyd4110
Vendor Member
Sep 7, 2013
1,171
336
Westminster, MD
www.boltonhooks.com
Dave, welcome to OTT.
Technically, you need a "Tandem Center" valve for everything but a motor. The term "Open Center" has gotten used, abused and misconstrued on most tractor forums and at the Surplus Center as well.
A Tandem Center valve will have the work ports blocked in neutral, thereby not allowing the cylinder connected to them to move.
A Open Center valve will have the work ports open to the T (tank) port in neutral, thus allowing a motor to coast to a stop or freewheel.
Clear as mud yet? :)
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
I thought all modern 'open center' valves with at least 2 work ports were 'tandem center' and thus the term got used. Only single work port units (lift and release types) were the old 'open center' definition.
Isn't the modern definition of 'open center' that incoming pressure flows to the tank until the spool is shifted and the spool will hold both work ports where they are (tandem center)?
The other definition is 'closed center' which has to have a pressure control system back at the pump to work right, right?
I haven't seen the neutral to tank work ports back to 'open center' in a long, long time... at least on 2 or more work ports. You're right though, I do see it on motor control valves all the time!
Kennyd4110
Vendor Member
Sep 7, 2013
1,171
336
Westminster, MD
www.boltonhooks.com
aeblank
411
Cadillac, MI
There is a guy on Ebay selling kits for $400. He says $45 more than the sum of the parts. Anyone have any experience? I want to get it for my dad for Christmas.......
Sent from my DROID RAZR using Tapatalk
