Old Brush Hog
Popeyecop
L175, L3901
Sep 14, 2017
20
Chester, IL
I dug up this old 48" Brush Hog and was wondering if its missing any parts just by looking at it. I would think it would require some sort of wheel attachment to use as a height adjustment. The gear box still turns freely and i'm trying to get it back into usable condition. Any suggestions?
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
While all new bush hogs have a tail wheel it may not have had one. What is missing for sure is the front part of the PTO shaft.
Popeyecop
L175, L3901
Sep 14, 2017
20
Chester, IL
It took me a little but to find the front part of the PTO, but a buddy of mine came to the rescue and give me what I needed to fix that.
I not sure what size bladesign it will take. The ones that were on there are rusted and broken. I coated the nuts and bolts with PB Blaster so hopefully when I go to replace the blase the nuts come off easier.
Popeyecop
L175, L3901
Sep 14, 2017
20
Chester, IL
It took me a little bit to find the front part of the PTO, but a buddy of mine came to the rescue and give me what I needed to fix that.
I not sure what size blades it will take. The ones that were on there are rusted and broken. I coated the nuts and bolts with PB Blaster so hopefully when I go to replace the blade's the nuts come off easier.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
Apply a mixture of 50/50 ATF and Acetone it out performs PB by a mile. Any tags on that with a number? It looks like it had a tail wheel at one point you may have to fabricate one, but if you can rebuild it it's worth it. Change out the gearbox oil too.
Popeyecop
L175, L3901
Sep 14, 2017
20
Chester, IL
Thanks for the info on the mix, I will be trying it. I'm having trouble locating replacement blades. Everywhere I look the blade's have a bend in them. The one on it are straight.
