Old B5200
7,100
Re: Old b5600
Harlin, you need to give a bit more information. Non hydo means geared transmission? Engine starts but tractor does not move? What specifically have you done?
And you mentioned in the title a B5600, but you mention a B5200. I take it you have a B5200, correct?
Harlin Huskey
Kimberling city mo.
Re: Old b5600
Yes it it a geared trans. Running with it in gear clutch out I have no no noise no movement of you push clutch in it has pressures on it as if throughout baring is going against the pressure plate. It makes no diff in 2wd or 4wd
7,100
Re: Old b5600
Sure enough sounds like your clutch has given up the ghost.
You're satisfied they clutch linkage is allowing enough pressure to push the clutch as far as possible?
