OK what am I missing
5,122
The mower deck on the BX needs,,, aliened or something . The right front corner is down the rest of the deck raises but the front wheel just hangs to the point the anti scalp wheel is always on the ground even with the deck all the way up. I have the book for the deck, but either I am not reading what it says or not understanding.
So my orange geek brothers please tell me WTF am I not seeing? More than likely it will be a DUHHHHH moment so lets have it.
2,842
Not knowing exactly how it attaches to the tractor but assuming it has some type of hanger on the front…
Look at that side of the hanger and see if the deck is attached properly. Highlight in yellow and red. I put a question mark on something else that could be wonky but I have no idea what it does.
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,287
930
Minnesota
Remove and install again. If it’s doing the same thing, something is bent/broken.
Orangeglow
2015 BX2370
Jun 19, 2014
397
215
Prescott, Ontario
Russel, that is a great diagram, with lots of good info. The piece you highlighted with a question mark locks the complete section you marked in yellow to the front frame of the tractor, to hold everything up and in place. Skeets, I have the same mower. Make sure the two back supports for the mower are locked in properly. If the left one isn,t in correctly, you would only be lifting one side of the mower, which would cause the tilt.
John T
2017 BX23S
May 5, 2017
1,239
769
under a rock
anti scalp wheels should Never touch the ground on a level surface.
adjust those first.
then measure side to side deck height. The adjustment bolts and on the back of the deck where the lift arms Pin to the deck.
they sell a nifty tool to measure blade height, I think john Deere makes it.
measure the left and right side blade height.
I'm sure there are videos on the yew tube if you need additional guidance.
John T
2017 BX23S
May 5, 2017
1,239
769
under a rock
And while your down there, take off the blades and touch them up.
If I know you, your probably out there sharpening up the rocks in the yard..... :LOL::ROFLMAO:
4,060
Sorry if this hi-jacks for a moment…. but when discussing “anti-scalp” wheels …and they not supposed to be riding on the ground…. ??
I have a finish mower like this one…. Are these wheels NOT supposed to be riding on the groupnd..?? That is exactly how I’ve been using this mower for 5 years…. lower the 3-pt to let the wheel support the mower.
Have I misunderstood these wheel’s purpose..??
Orangeglow
2015 BX2370
Jun 19, 2014
397
215
Prescott, Ontario
Geohorn, in case you aren,t joking, yours is a different kind of mower. Yours looks like a 3 point hitch setup, so of course it needs to ride on the wheels.
Skeets mower is suspended under the tractor and uses a setup that hangs the mower at three different points, so the wheels on his mower should not always be touching the ground.
4,060
I suspected the same…but confirmation never hurts… thx
5,122
Sorry, no things have been a bit hectic the last couple days around here. Though I am thinking the the nuts on the hanger have loosened and worked its way up the threads making the hanger longer on the right side. I could be in left field, but thinking that might be the issue, or the bracket welded to the mower deck has been cracked loose. I ll be back when I figure it out ;)
