Oil specs
3,102
What is the recommended oil specs for d950 also synthetic or mineral
I am not sure what you are asking.
Oil is not oil - yes, it does have specifications. But that typically goes by factors that are easily understood
Diesel or Gas? Easy
Cold, warm or moderate climate - sometimes all three in the same year.
Synthetic vs mineral based - well that is easy, synthetics are far superior in all regards, it has better flow characteristics and will not break down as fast. Many will tell you that it causes oil to seep out of seals....
the oil MAY leak out, but simply the seals are worn already.
In your neck of the woods, where it is not real cold nor real hot year round, I would use 15w-40 T6, if that is hard to find there - a 10w30 diesel oil will work perfectly. Both in synthetic.
7,467
The operator's manual has that information.
The original recommendation was SAE viscosiy grade 10W30, API service category CD.
Today that would be SAE viscosity gradw grade 10W30, API service category CK-4
Synthetic or conventional is your preference.
skipper1
Front loader and back hoe
Sep 27, 2026
Ireland
Diesel or Gas? Easy
Thanks very much
skipper1
Sep 27, 2026
Ireland
Thanks very much
4,309
