I blew a line on my bush hog back hoe. What oil do I use? On the back of the tractor there is a site glass that is a milky white color. Is this the normal color or do I have water in it or has it become foamy?? Thanks
If you checked it shortly after blowing the line it's probably just foamy, but if it was a while then change out the filter and fluid.
I would go with SUDT 2 also to keep everything running smoothly.
