Oil leaking from weep holes
sparky76266
L235 fwd loader
Aug 2, 2019
Sanger
I got a l235 replaced water pump and seal on front engine shaft and can not see any oil leaks but I have oil leaking a lot of it coming out of weep holes above the front axel and I’m at a lost as to where it could be leaking any ideals where it could be
4wd with loader
sparky76266
L235 fwd loader
Aug 2, 2019
Sanger
Replaced That and do not see any leaking from that area but it still pouring oil out somewhere leaking out the Weep hole
8,362
Seeping leaks or pumping out?
If it's pumping out, there are some holes in the block with plugs from the oil passage drilling process that could be the cause, get a couple more posts under your belt then post a picture of the leaking location. ;)
