I noticed yesterday that suddenly oil levels were extremely high. Started the tractor and suddenly oil was blowing out of what seems like an overflow tube on the crank case. After some research seems like it could be a couple of things. I know it may be the hydraulic pump with a bad seal putting hydraulic fluid into the oil or it could be piston rings. However I'm leaning towards the pump. Does anyone have a good diagram of where this hydraulic pump is located? I've gut the kubotabooks 7200hst work manual but my 7200 seems to be a bit different than the HST model. I believe my model is 7200E. It is the 2wd manual transmission, not HST. If anyone has a breakdown on the location of this pump I'd greatly appreciate it.
