I have been fiddling with my used ZD326, which refuses to start without hot-wiring.
I thought I had a bad relay. Switching relays did not fix the problem, so I moved down my list. I checked all remaining safety switches, and they were fine.
I went under the seat, disconnected the ignition switch plug, and tested for continuity between the red (hot) and black/yellow (start) wires with the key on "start." I got 300K ohms, which seems a tad high compared the ideal value of 0.
My question: is an OEM switch worth the extra money? Call it $100 after shipping and so on Chinese switches can be had for about $23.
I am going to pull the old switch and see if I can clean it up for now. I am hoping the switch really is the problem, because if it's not, it could be the controller. Before I would fool with that expensive part, I would start scraping grounds all over the mower.
