Non starting m9000
Solo3857
M9000
Feb 9, 2022
Georgia
M9000
Has no power to the starting side of the selinoid but does have power to the run side. Therefore it will not start? Any help is appreciated
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
Be sure what terminals are supposed to be energized and when. The fuel shutoff solenoid may only get power for a few seconds when you turn off the key. That stops the flow of fuel to kill the engine. If you have access to a schematic diagram it may help.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,272
176
Coyote Flats,Texas
Welcome to OTT
Sounds typical for inoperable neutral start switch or pto switch. Is trans shifter in neutral & pto control in off position?
9,410
M9000
Are we talking about the fuel cut off solenoid?
