No start issue
dmoore
2006 B7800, RC72-BA 72" mid mount mower, RB 1672 72" rear blade
Feb 8, 2010
84
9
Exmore,Virginia
So I cut our 4 acres today with my 2006 B7800. Shut it down for an hour for lunch. Went to start it again to wash out the deck and nothing. Fuel solenoid clicks but no starter engagement. First time in 16 years this has ever happened. So I am thinking one of the safety switches must be the problem or blown starter fuse at the starter. Fuse checked out good. I grab a test lead with alligator clips and jump out the starter solenoid while pushing in on the clutch and key in the run position. Nothing. I then tie the seat down as to depress both seat switches. I jump the solenoid again and it starts. As soon as I untie the seat and 2 seconds later it shuts down. The PTO is disengaged if your wondering. So I jump out both seat switches and still the same thing. I am now wondering if the clutch safety switch is the culprit. It seems to be closing the switch externally. Tough to get to the boot to pull it up far enough and jump it out. This is where I stopped for now. At least I got it back in the barn. The PTO safety switch could also be the issue. I looked down in that area and there are two. Thoughts?
5,688
Without the wiring diagram it's near impossible to say exactly what is causing the 'no start' condition.
old tractor...could have a 'frayed or chewed' wire finally gave out, crap in some switch,loose connection,??
dmoore
Feb 8, 2010
84
9
Exmore,Virginia
Dead battery. Corroded contacts. Bad ground.
Battery is perfectly fine, I can bypass the starter solenoid and it cranks fast. Tractor is immaculate and is stored in my climate controlled building since I bought it new.
dmoore
Feb 8, 2010
84
9
Exmore,Virginia
Are there wiring diagrams posted here?
mikester
M59 TLB
Oct 21, 2017
3,878
2,522
www.divergentstuff.ca
Now that you've ruled out typical problems using logic you should simply start buying new parts for your immaculate tractor stored in the climate controlled building. Use the following order:
1. replace starter solenoid
2. replace key switch
3. replace starter
4. replace fuses
5,688
jumper +12 to control tab of starter solenoid, if it spins, solenoid/starter is fine.
follow 'control wire' back to where ever it goes(some safety switch ?),test there.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
I am leaning towards the pto switches, I am thinking the tractor thinks the pto is engaged. Does your tractor have a indicator light in the dash ? That could be one switch and the other for the start circuit. A test light would be very useful.
5,688
I grabbed the wsm, there's 3 safety switches ( clutch,pto, hst) that all have to be closed to ground the starter relay. you should be able to jumper to bypass the 3 switches. if it starts yo KNOW it's one of the 3 switches and/or their wiring.
if the 'preheat' lamp comes on ,then the main switch is supplying +12 to the starter relay
3,215
Curious, how did you bypass the starter solenoid?
B2710HSD
B2710HSD belly mower flail water bowser logging bench
Aug 12, 2011
9
CHEPSTOW UK
sounds similar to a couple of problems I had on my b2710 with the hst pedal switch. firstly the switch actuation mechanism was worn so would not activate the switch in the "pedal neutral" position. secondly the switch adjustment screw came loose and allowed the switch to move out of alignment with the actuation mechanism. lying on my back under the hst pedal side allowed me to see the operation of the switch to work out what was happening. Also the "pedal neutral" position on mine was in such a small envelope of operation that sometimes it was necessary to turn the key to the start position and slowly move the hst pedal to find the neutral start position.
5,688
re bypass
he may mean bypass the starter relay. from the wiring I saw, power from ign sw goes to one end of a 'starter relay' and the 3 safety switches are in series from the relay to ground. You can 'bypass' them simply by jumping +12 on starter to the starter solenoid contact...
3,215
re bypass
That is probably what the OP meant. Looks like there is no start relay on the B7800, just an output from the OPC to the starter solenoid, via a switch on the clutch pedal. Did not look further to see if there are other permissive inputs to the OPC. Certainly might be, as I believe the B7800 has a operator presence switch on the seat.
dmoore
Feb 8, 2010
84
9
Exmore,Virginia
re bypass
precisely
dmoore
Feb 8, 2010
84
9
Exmore,Virginia
Correct, a run switch & a start switch. Both jumped out they are not the issue. I have not had time to jump out the hydro & PTO switches just yet. I am thinking one of them is the problem. Thank you for the responses. I am ordering a FSM tomorrow. After 16 years I guess I will need one.
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,301
3. replace starter
4. replace fuses
No. This is just firing the parts cannon. It's the most expensive and frustrating way to fix a problem, and usually takes the longest.
There is a lot more troubleshooting to be done. Getting those wiring diagrams is the first step.
