No power whatsoever
mikfenn
L3301, various attachments
Jul 24, 2025
Madisonville, TX
Kubota L3301
Hi all,
Need some help or suggestions. Got on my tractor today, turned ignition key everything lit up and motor started to crank and then everything went dead, no power at all when i turn key. Checked fuses on left side of seat, all good, checked the 40 and 50 amp fuses under hood, all good. Battery tests good. Are there any other fuses? also which safety sensor would shut down all power not just stopping it from cranking?
Thanks
Mik
6,632
Kubota L3301
Hi all,
Thanks
Mik
Not a safety device. Fuse or bad battery connection. Consult the WSM for a wiring diagram.
3,000
Kubota L3301
Hi all,
Thanks
Mik
Should be a large amp fuse near the starter - a fusible link. If that blows - everything can be down.
https://www.orangetractortalks.com/forums/threads/l3301-ignition-problem.73485/
